08-03-2019 14:51
08-03-2019 14:51
I did a run this morning and my Fitbit recorded it perfectly along with a GPS map of the run. Later in the day I played 9 holes of golf and while the exercise recorded the map did not. I didn't change anything on the versa. My old versa always showed the map when I played golf. Is there a setting I need to change or is something else causing a problem. Any thoughts? thanks
08-03-2019 15:42
08-03-2019 15:42
Sorry, finally found the solution online. In the gear icon on the golf exercise on the versa, there is a GPS option which can be turned off or on. Mine was ON on my old Versa and was OFF on the new one. Problem solved.
