05-23-2019 02:54
05-23-2019 02:54
For the past 3 days my Versa has not syncing with my Samsung 6 phone app.
When I finally got it to the step count shows but no other data!!!
On my versa it shows my activity and active hours and sleep but after syncing none of it shows!
Im so upset that its not working but also at the fact that I cannot rely on it to track my progress, the reason I spent $350 for it.
Yes Ive tried
updating,
turning on and off,
Reinstalling the app and versa
...everything.
Please please help???
05-23-2019 14:27
05-23-2019 14:27
Hi, are you using a Third Party Clock Face? If yes, replace it with one developed by Fitbit itself and restart your Versa. Good luck!!
Best Answer05-23-2019 16:19
05-23-2019 16:19
How can I do this if my fitbit sync
Best Answer05-23-2019 16:26
05-23-2019 16:26
Hi, in the dashboard of your Fitbit app, press the Watch Icon on top of the screen on the right side. This will bringyou to the page with the Clock and Apps Tiles. Press Clock Faces and after that "All Clock Faces". You will see a new page with on top of this page "By Fitbit". Select "display all" on the right side of it and you'll see all the clock faces made by Fitbit. Choose one of them you like and press it and then press select. The watch face will then be installed on your Versa. After that, restart your Versa.
Best Answer05-23-2019 16:58
05-23-2019 16:58
Best Answer05-23-2019 17:09
05-23-2019 17:09
Which Clock Face are you trying to download/install?
Best Answer05-23-2019 17:17
05-23-2019 17:22 - edited 05-23-2019 17:24
Hi, when you selected Flare, did you press "Select"? If yes and it takes a long time to install it, quit the Fitbit app, put your Versa in the charger and connect it to your PC, restart the Fitbit app again on your device and try again. Also restart your Versa before performing these suggestions!
Best Answer05-24-2019 11:21
05-24-2019 11:21
