05-31-2020 05:17
05-31-2020 05:17
I have my versa over a year never any problems with my Nokia phone changed to a P30 Lite and now it won't show up messages and it could take 4 attempts to sync. Ive reinstalled it a few times and still not working properly HELP
05-31-2020 07:51
05-31-2020 07:51
Hi @Shirlscunningha take a look at the Android tips.
If you have tried the sync tips then next time with a sync problem try clearing the Fitbit apps or phones cache and stop the Fitbit app.
When it comes to notifications, do they show up on the phones lock screen?
Also check the notification tips.
Best Answer05-31-2020 08:59
05-31-2020 08:59
im getting this yes I get messages on my screen. I've switched the phone off numerous times and it still comes up unless I'm missing a setting. When I look at Bluetooth it's paired but when I try to drill into the versa it just let's me rename my versa and no other settings is on it
Best Answer06-03-2020 06:15
06-03-2020 06:15
I got the versa 2 and after setting it up it worked ferfectly with my p30 lite but it lasted only one day. On day 2 it failed to sync, didn't show any messages or my calls. I have reset it several times, I have deleted and reloaded the app all to no avail. So I have given up on it and now it's just a watch.
Best Answer06-11-2020 12:09
06-11-2020 12:09
I've changed to this setting and so far I'm getting messages
Best Answer06-11-2020 12:25
06-11-2020 12:25
I have used those settings and apart from calls notices I get nothing!
Best Answer06-11-2020 12:39
06-11-2020 12:39
Ah no was hoping it might help
