I’m so frustrated because over night my heart rate zones have increased 10 BPM. I took a brisk walk this morning for 30 minutes (which the fitbit autodetected as elliptical), and it says I never hit the fat burn zone. A couple of days ago, it would have said I was in the fat burn zone most of the time. Why the sudden jump?? Any help appreciated!
@LexiJRamirez and @SunsetRunner -
For the Ionic and Versa "Family" of Smartwatches and previously for the Charge 4, there have been changes to not only Active Zone Minutes vs Active Minutes but FitBit has also changed the formula for the Heart Rate Zones.
FitBit has apparently rethought its definition of "active".
FitBit has incorporated what is commonly referred to as the "Heart Rate Reserve" (HRR) formula for defining Heart Rate Zones. When calculated using HRR, they are often referred to as "Training Zones". A FitBit Community Council member whose opinions and support in the boards I happen to admire, pointed me to a New York Times article regarding HRR. But everything in the article seemed to be about athletes in training, including an Olympic hopeful in canoeing, and not your regular John and Jane Doe.
I believe FitBit is doing their members a disservice by not allowing them to opt out of HRR and retain the Traditional Heart Rate Zones formula, and have stated so numerous times.
Just so you understand how the zones changed -
The Heart Rate Zone calculations have moved from the Traditional formula which are straight fixed percentages (50, 70 and 85%) of your Max Heart Rate which is defined as subtracting your age from 220. For me, as a 68 year old male, my Max Heart Rate is 152. Traditional zone values for me are shown in the first data row below.
BTW, there is another tweak to the "traditional" method for women where 88% of the female's age is subtracted from 206 to get their Max HR. So, for a 31-year old female, Max HR would drop from 189 (220 - 31) to 179 (206 - 27). But FitBit apparently does not subscribe to that definition.
As I mentioned earlier, the new formula being used by many FitBit devices, including the Versa 2 as of the latest release, use a value called Heart Rate Reserve. Subtracting your resting heart rate from your max heart rate results in that reserve.
40% of the reserve is added to your resting heart rate to establish the beginning of the Fat Burn Zone.
60% of the reserve is added to your resting heart rate to establish the beginning of the Cardio Zone.
85% of the reserve is added to your resting heart rate to establish the beginning of the Peak Zone.
The new Heart Rate Reserve formula zones for me are shown in the second data row below.
Couple the new zone definitions with the change to heart rate defining "Active" changes things, something you have already observed.
For instance, you take a 30 minute walk without getting your heart rate up to at least Fat Burn.
Probably not what you wanted to hear, and I'm normally a pretty big cheerleader for the FitBit device/app combination, but to spring this on people with:
in my mind is unconscionable.
Good luck ladies, and welcome to the boards.
It’s really disappointing because it also does not take into account if for example, you have a back injury or any ailment for that matter. I loved the traditional one because at this point, I cannot get into fat burn mode, therefore I feel like I have achieved nothing.
@SunsetRunner -
While I do have a back injury dating back to my service as a Marine (way back), I also take Beta Blockers due to a viral attack on my heart in 2017. As such, my heart rate is throttled even during exercise, the Harvard Medical School and more importantly my cardiologist has advices reducing the traditional Max Hr by 20%.
FitBit has not taken either your back injury or my medication into consideration when they forced the "Training Zones" on you and I, as well as I believe, thousands and possibly millions of others when they do not allow for their customers to "opt out" of the new "features".
In the meantime, you do have an alternative. You cannot change from Active Zone Minutes back to Active Minutes, but your can redefine your heart rate zones by overriding your Max HR.
Your cannot perform that action in the mobile apps at this time, but...
You can change it in the Settings page in the Web Dashboard, save the change and sync your device. Of about a dozen people that have tried that when I recommended it, only one individual could not get it to take. Once person had to log out of the app and back in for it to take.
For me, I can offset the effect of the Beta Blockers, by changing my Max HR to 120, as shown below:
And you need to stay on top of it. The FitBit servers routinely reset the Custom Max HR override back to the "default" value of 220 - age. It has happened to me three times in the past 2 weeks.
Good luck.
Hello, you can override the new settings (which are ridiculous and not industry standards of HR zones (220 minus your age x 70-85%) to achieve your HR zones. Here is the over ride recommended by another user on this site which I have used Go to the fitbit dashboard on your pc or tablet (not the app as right now it is not working correctly). At the dashboard, tap the gear icon in the upper right hand side of the screen, then tap on settings, this will show your personal info, scroll down to the bottom of the screen to Heart Rate zones and change your Max Heart Rate to “custom”, put this number at about 85% of your MHR. For instance, I am 58 years old. 220-58 x 85% = 138 (rounded). I put 140 as my MHR zone in this field. Then I synced my fitbit and checked my HR zones and they are back to what I consider “normal” and I see the correct fat burn, cardio and peak numbers while I am working out again.
Hope this helps!
I am so glad you can relate! So frustrating!
Thank you so much for explaining all of this. I am a religious exerciser, but I am not a training athlete. This changed makes me feel discouraged because it seems like I don’t get much credit anymore for my exercise. Thanks again for your detailed response.
Hi Lexi,
I absolutely relate. There would be soooo many people who will be unable to sustain the changes. I hope they revisit this as there potentially could be new to exercise people who just give up.
Ladies -
Keep on top of the Max HR override that @CindiLi pointed out to you. I performed the override on September 3rd, after my semi-annual Cardiologist appointment and have had the FitBit server reset it three times since.
No real biggie, just a bit of a nuisance. You only have to go back and change it again and sync your device.
Yes, thank you for this explanation. I will adjust my max Heart Rate. I just got the versa and was about to return it but I have 30 days to do that through amazon, maybe if i can get this to show correctly I will keep it, not sure. I have the charge 3 on and the versa. The numbers seem close accept this and it seems very disappointing to know I lifted 50 pounds a minute for 10 hours at work and it says I never hit fat burning mode when normally I would have hours of active minutes. The same when I teach skiing 7 hours a day in the winter. I know I'm breathing in fatburning mode way before this adjustment says. The charge 3 still uses the traditional zones but I have it had 1 year and 3 months and they replaced in May for a corrupt screen and it went corrupt again after only 4 months so I don't want to buy a new charge 3. I hear the very affordable Garmin vivosmart 4 is excellent for someone like me that cycles so maybe if I don't like the versa I will go that route. This is not a good change. I'll feedback my thoughts also. Oh I lowered the Max HR to 155 on mine (I'm 55), but that still only lowers my fat burning mode to 96 though it gives me a proper cardio zone off 115 same as the charge 3 shows. My current fatburning mode on the charge 3, still using the old standard measures is 82, so 96 still says I was barely active when I was extremely active and know it.
Siggh, all it does when I put in the 85% is make my zones smaller. My lowest number for fat burn is 95, and I check it every day. It just refuses to lower fat burn zone. 95-110 Fat burn, 110-128 Cardio, and 128 and up Peak.
I am feeling the same way. It doesn’t seem accurate to me at all. I will not purchase the Charge again.
Cindi I have tried to fallow your steps and I’m not finding a way .. I’m not very computer savvy .. I have iPad not pc so maybe that’s the difference .. can u explain one more time thank you
Best AnswerThanks, Cindy.
I had an Alta HR for over 5 years and frequently was in Fat-Burning with even a little time in Cardio. But since upgrading to the Charge 5, I recently spent 87 minutes in a brisk walk - sweating and huffing & puffing, going up inclines - and yet somehow managed to not log a single minute of those 87 minutes in the supposedly "easy" Fat-Burning Zone. There is nothing as sublimely irritating to see your readiness score at 100 the following day because - according to FitBit - you spent the entire previous day sitting on your rear, when in fact, you knocked out 20K steps, which included a nearly an hour-and-a-half of constant brisk walking.
I have no idea what's in Fitbit corporate's head here. It's like they want you to become demoralized.
