03-22-2020 06:06
03-22-2020 06:06
My versa just stopped tracking my heart rate on Thursday. I’ve followed all the advice and have done the following:
- toggled heart rate tracking on and off several times on device
- rebooted device several times
- done factory reset
- emailed customer support (awaiting response)
Any other tricks I should try? The green light at the back of device isn’t flashing.
Thanks
03-22-2020 06:19
03-22-2020 06:19
Hi @JoannaGroo - Good job of trouble shooting and letting us know what you have tried. Here are a couple more things to try:
Please let us know if any of this helps.
Best Answer03-22-2020 07:49 - edited 03-22-2020 08:27
I’m having the exact same problem, which started Friday night. I’ve done all the suggested troubleshooting. My wrist placement hasn’t changed from when it was working, and I’ve cleaned the sensors according to the care instructions. The LED lights stopped flashing green and had a faint red flicker. After running the battery completely out, and charging to 100% capacity, there is no light at all. Any other suggestions?
Best Answer03-22-2020 08:01
03-22-2020 08:01
Best Answer03-22-2020 08:06
03-22-2020 08:06
Exactly the same as mine re the LED’s, green one not on and a faint red on in permanently. V annoying.
a couple of weeks ago my heart rate was constantly reading 100BPM so I rebooted and that was resolved and now this.
Best Answer03-22-2020 08:12
03-22-2020 08:12
I’ve not had that problem...yet!
