06-23-2018
08:00
19:27
EdsonFitbit
06-23-2018
08:00
19:27
EdsonFitbit
Since yesterday the heart rate sensor has been not tracking my heat rate. Any ideas on how to fix that? Or is this a common bug? I don’t know if this is a reason or not, but the heart rate sensor has been glowing red instead of green for two days now.
Moderator edit: added label
06-24-2018
06:57
17:33
06-24-2018
06:57
17:33
It's great to see you around @thequestionman.
Have you tried to restart your Versa? If you haven't, I recommend restarting it by doing the following:
Let me know the outcome. ![]()
06:59
04:15
AlejandraFitbit
06-24-2018
06:59
04:15
AlejandraFitbit
Yah, I tried that. I tried factory resetting it, unpairing and pairing again, but still nothing. I bought it more than 45 days ago. And I don’t think the warranty covers unsatisfaction. What I’m thinking is to just buy an Apple Watch series 1. With all these software bugs I want to know there won’t be product breaking bugs.
04:19
17:33
06-25-2018
04:19
17:33
Thanks for the update @thequestionman.
Since the instructions provided didn't work, I've gone ahead and escalated your case to our Support Team, for them to take a deeper look at this, please keep an eye on your inbox for further instructions. Also, for more information about our warranty policy, click here.
Catch you later. ![]()
Best Answer06-25-2018 11:17
06-25-2018 11:17
just so you know, new problems have appeared. firstly, when I get notifications theres no vibration. then when I charge the battery, not only does it last 10 hours on full charge but when I charge it, it stays where it is at the percentage and gets really hot.
08:17
17:32
06-27-2018
08:17
17:32
Thanks for keeping me updated @thequestionman.
Since a case is already for you, I recommend commenting this to the advocate in charge of your case. I know our support team will be glad to help you out with all this.
Happy stepping. ![]()
