Hi @VHenderson Is there still a green light flickering rapidly on the back of the watch?. Check the settings app on the watch to see that HR is still turned on.
Helen | Western Australia
Best AnswerThe green light is the heart rate monitor. It sends out green and red light and then measures the light that is reflected back and can tell how fast your heart is beating by the changes in the colour of the reflected light. Im sure that isnt a technically correct explanation, but its about the limit of my knowledge 🤣
If your heart rate is not being measured then sleep wont be recorded correctly either, as sleep detection depends on the heart rate being measured.
Try turning heart rate to OFF in the settings app on your watch and then restart the Versa sevefal times. Then go back to the settings app and turn Heat rate on again. If it is still not working then please come back here again.
