07-30-2019
15:47
07:23
AndreaFitbit
07-30-2019
15:47
07:23
AndreaFitbit
Why is the Fitbit displaying differently then the app? The steps per hour on my Fitbit is accurate but when I look in the app it’s missing info
Best Answer07-30-2019 23:13
07-30-2019 23:13
Hi @Steph3355 Try restarting your Versa several times and also uninstall the app, reinstall and log back in and hopefully it will work better from now on. Please come back if the issue doesnt improve.
Helen | Western Australia
07-31-2019 19:56
07-31-2019 19:56
Best Answer08-01-2019 00:42
08-01-2019 00:42
Oh bother! I have flagged a moderator to come and help you.
08-01-2019 07:41
08-01-2019 07:41
Welcome to the Fitbit Community @Steph3355. I´ll be glad to assist you with your hourly steps inquiry. Thank you for troubleshooting this situation with the instructions provided by @NellyG.
Could you please let me know if the hours you have completed the 250 steps don't match between your Versa and your App?
Thank you for the heads up @NellyG.
I'll be waiting for your response.
Best Answer08-01-2019 07:48
08-01-2019 07:48
Best Answer08-01-2019 08:44
08-01-2019 08:44
Thanks for getting back to us and for letting us know about this issue @Steph3355. Our team is aware of it and are working to identify a resolution as quickly as possible.
I appreciate your patience and look forward to getting you back on track.
Keep on visiting the forums.
Best Answer08-01-2019 08:54
08-01-2019 08:54
Best Answer08-20-2019 16:10
08-20-2019 16:10
Having the same problem and shows me inactive for an hour and 15 mins I was outsude gardening and moving, Did your problem resolve?
Best Answer08-20-2019 16:13
08-20-2019 16:13
Just started having this problem Versa says I'm 12/12 hours done. My app os wrong says 10/12 and that I was in active over an hour. Restarted fit bit. Also deleted App and readded it twice no change.
HELP!!! it's ruining my data .
Best Answer08-20-2019 16:58
08-20-2019 16:58
Best Answer08-20-2019 16:59
08-20-2019 16:59
