04-21-2018 13:16
04-21-2018 13:16
Can someone please tell me how to shutdown my Versa from my watch, please?
12-10-2018 19:21
12-10-2018 19:21
On my Versa I see that to turn it off Some say go to settings and then account but when I go to settings and click on it all I get is notifications and inspiration, help please!
Best Answer12-10-2018 19:22
12-10-2018 19:22
Mine doesn’t say about. It says notifications and inspiration.
Best Answer12-18-2018 09:15
12-18-2018 09:15
Thank you!!! My versa froze and I couldn’t get to the menu option and this did the trick! Thank you so very much!!![]()
Best Answer12-28-2018 18:51
12-28-2018 18:51
My Fitbit Versa was working great and I was getting all of my notifications but today I can’t get my emails, phone calls or text on my watch. I have tried everything! Anyone got any ideas on what I can do? Thank you
Best Answer04-04-2019 19:33
04-04-2019 19:33
Hello, my versa is stuck at the screen asking me to download the app. I have done so, repeatedly. The app is not linking to the versa since I factory reset during the server crash today. I have tried the 3 button reset with no luck. Any advice is
@SunsetRunner wrote:No, Terri, you can not Shutdown the Versa from the App. I would try the Restart several more times and if that doesn't work, you will have to go with a Factory Reset using the 3 button method described below since you don't have a display. This will return the tracker to the way it was when you unboxed it and you start all over again.
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time or otherwise don't follow the procedure precisely , the Fitbit logo reappears quickly and boots without factory reset.
appreciated.
Best Answer04-04-2019 19:38
04-04-2019 19:38
Hello, my versa is stuck at the screen asking me to download the app. I have done so, repeatedly. The app is not linking to the versa since I factory reset during the server crash today. I have tried the 3 button reset with no luck. Any advice is appreciated.
Best Answer07-02-2019 09:48
07-02-2019 09:48
I thought the same thing. There is actually 2 different places that say "settings". You want to swipe your home screen until you see settings.
I used to be able to shut it down just holding the left button 😞
Best Answer12-22-2019 02:51
12-22-2019 02:51
Thanks so much very helpful I was scared thinking ive messed up
Best Answer02-07-2020 12:20
02-07-2020 12:20
my Fitbit doesn’t allow me to go to the settings:(
Best Answer08-29-2020 16:37
08-29-2020 16:37
It shuts down that way but it doesn't completely turn off. The battery still drains when it is shut off. Is there a way to fix this.
Best Answer08-29-2020 18:23
08-29-2020 18:23
Best Answer06-01-2021 16:40
06-01-2021 16:40
I tried doing that. Unfortunately, my Fitbit Versa 2 does not have the "about" option under settings.
Best Answer02-06-2022 17:51
02-06-2022 17:51
THANK YOU
