09-26-2020 07:35 - last edited on 10-13-2021 09:13 by JuanJoFitbit
How accurate is the HRV in the health metrics?
04-27-2022 01:06 - edited 04-27-2022 02:06
My Fitbit charge 4 won't record HRV
I only get basic sleep details.
I swapped devices overnight with my partner as hers records her sleep score with no problems.
She got her score using my Fitbit and I got my usual basic details wearing hers overnight
I can only conclude that my mechanical heart valves throws the device into confusion.
Still at least I know what time it is on my wrist!
04-27-2022 05:08
04-27-2022 05:08
04-28-2022 16:42
04-28-2022 16:42
04-28-2022 17:03
04-28-2022 17:03
05-09-2022 16:43
05-09-2022 16:43
This! This was the post I was looking for… I hang out between 40 and 50 most days… I work out 6 days a week, twice a day. About 1:30-2:00 a day. RHR of 50-52… so the HRV of that amount almost seems impossible at the rate I’m at. If I’m extrapolating another 40 or so ms? 80-90 makes a lot more sense but also puts me in a solid range for a 43 year old. I need to test it another way now lol
05-09-2022 17:37
05-09-2022 17:37
So, what do you make of a chart like this for a 77-year-old man with a resting heart rate in the low to mid 50s?
05-09-2022 18:28
05-09-2022 18:28
Not sure I understand the ask here? I mean if HRV drops as we age and you’re here… and IF Fitbit is often off by what seems to be around 40ms (I saw a second post that seems to confirm this) then you’re in terrific shape lol.
05-09-2022 20:00
05-09-2022 20:00
Well, part of what I’m asking is why it jumps around like it does in this graph. I thought it was suppose to be somewhat stable with only gradual increases or decreases, and that the trend, up or down, was suppose to be indicative of a good or bad, respectively, balance between the parasympathetic and sympathetic nervous systems. So the relatively large changes from day to day would seem problematical.
05-09-2022 20:40
05-09-2022 20:40
I think that’s what the bulk of the commentary is discussing. Granted I’m not sure about the stability but the large day to day swings may be something to explore. Personally I’ve saw swings after nights of heavy alcohol use (162 days dry) but I have largely stable readings that move slowly up and down between 40 and 50. Almost in a wave pattern.
05-10-2022 02:50
05-10-2022 02:50
My HRV drops when I am under stress and after consuming alcohol. I have been watching it and connecting the dots to other things going in my life besides exercise and sleep. It is hovering around 44, which is ok for my age from what I’ve read (I’m 44), but drops to 18-25 during high stress, after drinking, etc.
05-10-2022 05:56 - edited 05-10-2022 05:56
100! boozing always crashed my HRV; I find if my breathing rate jumps or I’m really dehydrated (live in a drier climate, if the humidifier isn’t on it impacts)… if I have a rough sleep. Nights like these I’ll see “crashes”. But if the data here is accurate, I’m probably 30-40 points better which puts me in a healthy range that I can stop freaking out about lol. This thread is great for health anxieties and I’ve recently learned I have a lot 😞
05-10-2022 06:20
05-10-2022 06:20
05-10-2022 07:15
05-10-2022 07:15
Heart rates In exercise section and heart rate section are completely different, for same period of time (exercise time). I have asked it a few times and sent screenshots, but no explanation...
05-10-2022 07:27
05-10-2022 07:27
Hr in exercise section records every second. Hr in hr section is your average hr in 5 min intervals. So that is the reason why it will never match. Hr in hr section will always be lower vs the hr in exercise section due to the averaging.
05-10-2022 07:54
05-10-2022 07:54
05-10-2022 08:29
05-10-2022 08:29
05-10-2022 09:25
05-10-2022 09:25
If you open the app and compare the HR on your watch or device to the top number, they will be relatively in sync. The smaller bottom number remains static and will
match the RHR data you can dig up by both tapping that specific section and the Health Metrics, which gives the break down for the evening.
they are discussing under the exercise section which would record the variation in the HR during a period of exercise and averaged out under that section alone.
05-10-2022 09:35
05-10-2022 09:35
05-10-2022 17:03
05-10-2022 17:03
05-10-2022 20:08
05-10-2022 20:08
