06-23-2018
17:20
17:20
EdsonFitbit
06-23-2018
17:20
17:20
EdsonFitbit
I have a charge 2 and Versa connected to my one account but is there a way that I can make the versa my primary device as my dashboard only displays the charge 2 at the moment
Moderator edit: added label
06-23-2018 18:42
06-23-2018 18:42
I dont think there is. With my Ionic I have set it up as the only tracker on that account and it seems to function better that way. I have another secondary account for my other trackers.
I believe there was a setting when I went to the app on my laptop to make one tracker the primary tracker, so if you have a laptop you could try that, but it is so long ago that I cant remember where the setting was exactly!
Helen | Western Australia
06-23-2018 18:55
06-23-2018 18:55
On a computer, go to Fitbit App dashboard and click on the Account Icon at the upper right and then Versa. Scroll down to "Use as Primary Device" and then sync your tracker. I'm assuming this for Versa because it is this way for Ionic.
