05-16-2018
06:40
18:07
EdsonFitbit
05-16-2018
06:40
18:07
EdsonFitbit
I have tried a numbers of different clock faces on my new Versa, all of which say they support 24hr clock face but none of which actually do. How do I get a 24hr clock face on my Versa? I am an android user, not sure if that helps?
Thanks 🙂
Moderator edit: added label
@Praj123 wrote:I have tried a numbers of different clock faces on my new versa, all of which say they support 24hr clock face but none of which actually do.
How do i get a 24hr clock face on my versa.
Thanks 🙂
Go to Fitbit.com Dashboard and click on the gear icon at the upper right and then on Settings. Scroll down to "Clock Display Time" and make your selection. Scroll on down and click on Submit and sync your tracker.
Thanks 🙂
It's great to see you here @Praj123 and @SunsetRunner thanks for the stopping by.
I am glad to see here that our friend replied your clock format inquiry. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up! ![]()
