09-25-2023
00:26
04:45
09-25-2023
00:26
04:45
How do I delete click faces? I can change one but if I try to change another it deletes the new one I've put on, not the old one. I have the Versa2
Hi there, @SunsetRunner. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
As a first approach, please note that in order to update the clock face on your watch, you must have no more than 38 apps installed.
With that being said, please also know that you can save up to 5 clock faces to switch between them:
For more information, please see How do I change the clock face on my Fitbit device?
HI @SunsetRunner - in addition you can only remove any clock face except the first [active] one in the Fitbit App Gallery tile.You must sync your watch first though so that the Gallery tile reflects what's showing on the watch properly.
If you are adding clock faces it is probably a good idea to have one empty [+] slot [by deleting others] before you start.
