12-24-2020
02:48
04:28
12-24-2020
02:48
04:28
Can you help with steps on how can I disable the PIN or device lock on my Fitbit Versa?
12-24-2020 04:31 - edited 02-23-2024 07:39
Hi there @TerryO_25, it's nice to see you around the Community Forums.
To reset or change the PIN code on your Versa, please do the following:
For more information, see How do I use the device lock on my Fitbit device?
Keep in mind that if you set up Fitbit Pay, the device lock is turned on automatically and you’re prompted to set a code. For more information on how to use Fitbit Pay, see What should I know about Fitbit Pay?
You must enter your PIN code at least once a day. Your Fitbit device prompts you to enter your PIN code based on your device lock setting:
Best Answer12-24-2020 04:31 - edited 02-23-2024 07:39
