04-26-2022
20:38
07:04
AndreaFitbit
04-26-2022
20:38
07:04
AndreaFitbit
Please make it so that daily steps can be edited. I charged my fitbit and while it was charging 23,000 steps were added but not taken by me. There should be an easy way to edit steps when this happens. Also when adding activity, is should allow the option of how many steps. Please add this option to the fitbit app so when unwanted steps pop up they can be corrected.
Thanks!
04-27-2022 07:10
04-27-2022 07:10
Welcome to the Fitbit Community, @Leighhengel. Thank you for sharing your suggestions steps and activity.
You can’t delete steps and floors; instead, log a non-step-based activity such as driving to override the steps or floors:
Do you want to add an activity with a predetermined number of steps?
I hope this information helps.
04-27-2022 07:10
04-27-2022 07:10
04-27-2022 07:23
04-27-2022 07:23
04-27-2022 07:47
04-27-2022 07:47
Ignore my message about the driving activity above not working. I finally go it to take away the steps that had been added between 7am and 9am while my fitbit was charging. I still would like to see an easier way to edit steps when situations arise like this. Thank you for your help!
04-27-2022 08:49
04-27-2022 08:49
Thanks for getting back to us and for sharing your concern @Leighhengel.
The best place to make your voice heard is the Feature Suggestion board . If a similar suggestion has already been made by another member of the community, you can vote for their suggestion and add your comments.
