08-29-2018
05:03
07:06
AlejandraFitbit
08-29-2018
05:03
07:06
AlejandraFitbit
My Versa currently displays the 7 exercises preset at the factory. I would like to swap them out for some of the other options like:
How do I do that? thanks in advance,
Shane
08-30-2018
07:07
10:52
08-30-2018
07:07
10:52
Hey @Shanew60, great to see you here.
If you want to edit your exercise shortcuts, I recommend taking a look at the help article How do I customize the exercises on my Fitbit device? and follow the instructions provide there.
Let me know how it goes. ![]()
Best Answer@Shanew60 The article @AlejandraFitbit references is helpful. However, a tip - at least the Android version is a little buggy. If you want to remove exercise shortcuts, you need to remove them one at a time and exit the screen to save in between. Or it won't remove them.
05:59
08:31
11-02-2020
05:59
08:31
It's great to welcome you, @evey35.
If you want to edit your shortcuts, make sure to follow the steps in the article: Can I change or reorder the exercises on my Fitbit device?.
Keep me posted.
Best AnswerI had the same issue, this helped me sort it:
