02-20-2025
11:45
17:14
EstuardoFitbit
02-20-2025
11:45
17:14
EstuardoFitbit
My husband lost his versa 3 two days ago outside. Is there anyway to locate it ? If not should get a versa 3 or versa 4 to replace it ?
02-20-2025 17:13 - edited 02-20-2025 17:14
Hello there @cherylmurphy, welcome back to the Fitbit Community!
Thank you for letting us know about this. I'd be glad to help.
Unfortunately, the only way to locate your device is through syncing with the app. Go to the area where you think you might have dropped it. If your device syncs, that means it's nearby. If syncing doesn't work, there isn't anything else you can try.
Regarding a new watch, both are pretty solid devices. If you are already used to the Versa 3, I'd stick to that one!
