07-25-2020 13:25
07-25-2020 13:25
Believe me I have been through settings profile, clock formats, units.... I cannot find a way to convert to the 24hour clock. Can anyone provide a step by step guide?
I have looked on the previous post but there does not seem a way to change it
07-25-2020 14:10
07-25-2020 14:10
Hello @Thechook and welcome to the Help forums. You make this change on your web dashboard at fitbit.com. Login to your account at fitbit.com. There is a gear icon in the upper right. Tap or click on the gear, then Settings in the dropdown. You will be on your Personal Info page. Scroll down to Clock Display Time and change it to 24 hour. Once you set this, it becomes an Account Setting. Any new device will automatically be on a 24 hour clock.
Laurie | Maryland
07-25-2020 14:08
07-25-2020 14:08
Hi @Thechook if your clock face looks at the global setting, go to your settings on the web and change it to 24 hour.
How do I change the time on my Fitbit device?
Now if you have chosen a watch that doesnt look at global settings, they may have their own option for 24 hour.
Best Answer07-25-2020 14:10
07-25-2020 14:10
Laurie | Maryland
07-25-2020 14:19
07-25-2020 14:19
Lzeew thank you!!! Taken 5 years to sort that xxx
