10-14-2023
21:14
06:16
10-14-2023
21:14
06:16
How do I unpair and delete all data on my versa 3 from my android phone so I can install another fitbit.
When I tried all the old data was still on the phone.
10-15-2023 06:22
10-15-2023 06:22
Hi there, @SunsetRunner. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the issue with your Versa 3.
Please note that replacing your existing Versa 3 with a new Fitbit device won't delete your history if you keep using the same Fitbit account. If you want to start from scratch with your new Fitbit device, you'll need to create a new Fitbit account.
do you want to keep the history of your account? If you delete the account, the history will be gone, too. If you just want to remove a device from the account and continue the history, you can do that. follow the directions in this article - click - on how to set up a replacement device.
For more information, see How do I delete my Fitbit account?
Best Answer10-15-2023 07:06
10-15-2023 07:06
@MarreFitbit I was curious how that's going to work with google accounts. Certainly people aren't going to want to have to make a new google account to use across all devices just if they want a new Fitbit start? Just wondering, as I currently would see no reason to want to erase my history in Fitbit.
Best Answer10-15-2023 12:49
10-15-2023 12:49
10-15-2023 12:55
10-15-2023 12:55
Best Answer10-15-2023 13:02
10-15-2023 13:02
@SunsetRunner Hi. I always just go into the app settings and add a different device to switch Fitbits. Never had an issue. Your historic data is stored on the Fitbit server, not the phone. So as long as your using the same account, it is supposed to be there. Some would suggest removing the Versa 3 from your app first before adding the new device, but I never had an issue just swapping.
Best Answer10-15-2023 13:44
10-15-2023 13:44
Best Answer10-15-2023 13:54
10-15-2023 13:54
@SunsetRunner No sorry, I don't plan on switching for a while to Google. You can't go into your Fitbit phone app settings and remove the Versa 3? I would think the phone app is the same, you're just logged on through Google?
Best Answer10-15-2023 14:54
10-15-2023 14:54
Best Answer10-15-2023 15:08
10-15-2023 15:08
@SunsetRunner I always got through to chat support pretty quick. This is mainly a user community anyway. Not actual support.
