09-12-2018
04:09
15:47
EdsonFitbit
09-12-2018
04:09
15:47
EdsonFitbit
I am visiting Italy and wants to reset the local time here on my versa fitbit.
how do you do it
Moderator edit: added label
09-12-2018 04:55
09-12-2018 04:55
There are a couple of ways to do this. If you are taking your phone and using a local phone service (which should put your phone on local time) then you can go to the app and on the home screen tap on the upper right icon (the one that looks like a document page) which brings you to the account page. Scroll down and tap the 'Advanced Settings' tile and turn on the 'Automatic time zone' switch.
If you are not going to link to a local phone service then just below that is the 'Select time zone' tile. Tap that and you can manually set the time zone.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
