05-27-2020
01:25
10:01
AndreaFitbit
05-27-2020
01:25
10:01
AndreaFitbit
My watch battery went flat, I have recharged it now, but the time is 1 hour and 30 minutes slow.
Which is the length of time the watch was down for.
How do I reset the time?
Thanks
05-27-2020 01:26
05-27-2020 01:26
You can't manually set the time, but it should reset itself whenever it syncs to your phone or computer based on the time on that device. Does your fitbit seem to be syncing ok since you recharged it?
05-27-2020 01:26
05-27-2020 01:26
05-27-2020 02:23
05-27-2020 02:23
Thanks all good now, not sure why it wasn’t synced. Thanks again
Best Answer06-29-2020 10:37
06-29-2020 10:37
I’m having this same issue - I have synced and restarted and it doesn’t seem to be correcting the issue - any advice would be gratefully received
08-18-2020 13:54
08-18-2020 13:54
I have resynced several times and it is still 10 minutes behind
04-08-2021 02:19
04-08-2021 02:19
I’m having similar issues: time zone change. I’ve synced a number of times, using both data connection & WiFi but no joy...
