01-02-2020
14:41
11:35
01-02-2020
14:41
11:35
I want to save my clock face
Hi there, @MasterHacker38. Welcome to the Community Forums. Thanks for sharing those steps, I'm sure they will help other users having difficulties to save clock faces on their Fitbit devices.
For more information, you can always see How do I change the clock face on my Fitbit device?
Best AnswerHi @Bayleeboo , do you have the latest Firmware on your Versa, e.g. 70.1.14? If yes, this version has an app called "Clocks" with which it's possible to save up to 5 Clock Faces. So, go to the clock face you want to install, select it and it's installed on your Versa. Allow all permissions and, if present, adjust the clock face to your liking. After that, go to clocks - my clock and you will see on the bottom of this page the installed/saved CF's. Regards kuzibri
Best AnswerGo to discover on the Fitbit mobile app and go the the Clocks and Apps Gallery. There should be 3 tabs. 'clocks' 'apps' and '{your device here}' for me that third one is 'sense' since i have the Fitbit Sense. From there you should see the five clockfaces you instaled on your device if you click one(that is not your active clock face) and scoll all the way down you there is an option to 'remove clock face'.
