03-29-2023
17:54
07:40
WilsonFitbit
03-29-2023
17:54
07:40
WilsonFitbit
I want to set up a used Versa but don't know if it's a Versa 2,3 or 4. How do I do that?
Hi @cowjazz easiest way is to download the app and when you go to set it up, it will ask you if you want to set up and it will tell you which device you have. You have the right charger unit? The person you got it from should be able to tell you which Versa they had.
