10-25-2018
01:13
11:35
AlejandraFitbit
10-25-2018
01:13
11:35
AlejandraFitbit
There's a weather app on the watch and when I click on it, it says no location information and to go to the mobile app to set up weather - I can't find it anywhere on the app or online?
Hi @SunsetRunner - It is a little confusing. If you go into the account tab on the app (upper right corner of the main screen), then into the Versa settings (just touch the picture of the Versa), then into Apps. Just scroll down to the weather app and go into permissions. Just be sure that Location is turned on. Let me know if this explanation isn't clear. Good luck!
10-28-2018
11:36
04:57
10-28-2018
11:36
04:57
A warm welcome to the Community @SunsetRunner and @Ozzie65 thanks for stopping by.
Regarding your inquiry, to set up the Weather app:
Let me know the outcome. ![]()
Hi @SunsetRunner. Perhaps some screen shots will help.
First, it is critical that you select Versa. This ensures that you will find your way to the apps available for the Versa .
Next, select Apps.
Then, tap All Apps and scroll down to Weather. If you cannot find the Weather app in All Apps, there is a search function. You can use that. Please let us know if this works out for you.
Thanks!Someone knows what’s going on!
20:01
04:16
JuanJoFitbit
08-08-2019
20:01
04:16
JuanJoFitbit
Hi Jayne - I finally figured it out thanks to the images below. No one mentions you do this on the phone. (I went to the computer app). In the Fitbit phone app, look for the tiny picture of your watch where the battery charge is. Press that (for a good second) and it will open the window shown below in the pictures. From there it's just like the pictures.
The pictures posted by Carol B
Moderator edit: merged reply
Thanks for the feedback, @pdiana1123 . I’ll make sure I specifically specify where you start - app or online - in future replies.
Best AnswerHi,
I'm Stephen.
Can I ask something?
My fitbit versa can't cognize my current location.
When I try to add my city, it's not show anything.
What should I do?
Please help me.
Thanks.
My first Fitbit and I can't set up the weather app. There is no where on the app to follow these instructions. Please help!!! Thanks in advance.
Best AnswerThere is no gear next to the weather icon. So confusing. This should be easier. The consensus seems to be this is an issue for most, setting up the weather app.
Best AnswerJust got my fitbit versa lite- so excited. How do I get the weather app to appear and how do I set it up?
Best AnswerOn your phone go to Fitbit versa app then find Fitbit icon and click on it. Then go to Apps - weather and click on gear icon. First line shows Celsius if you click on it it gives you and option to change.
Best AnswerI, too, have done all the steps, but it still shows no locations on my Versa 2. I'm wondering why the instructions work on some and not on others.
