04-04-2023
03:02
08:06
04-04-2023
03:02
08:06
Hi there
Does the versa 2 have a rowing activity just like walking or running ? if so, how do I get my versa 2 to recognise this activity ?
cheers
@se_0102 The Versa 2 doesn't have an indoor rowing shortcut. Use the Workout shortcut. You should be able to rename it to rowing after the fact by using the Categorize Exercise option in the Exercise Details.
Laurie | Maryland
Best AnswerHi
Thanks for that.
Sorry I should have been more explicit:
I have a versa 3 , and IOS 16.3(20D47)
I've looked on the settings/ activity & wellness/exercise but don't seem to be able to edit one of the exercise activities types
so I guess this isn't the right place to change an exercise types ?
cheers and thanks for your help
Hi there, @se_0102. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the inconvenience with your Versa 3.
As @LZeeW mentioned, please note that when a specific exercise is not available within the exercises we offer (such as Rowing), we suggest to use "Workout". Once you finish the activity, you can rename the activity to "Rowing Machine". Note that the information to enter will change depending on the nature of the exercise. To give you an example, if you change from "Workout" to "Run", it won't remove the calories but will add distance as the main stat to be displayed, this happen depending of the activity you are categorizing. However, your the data already tracked will be still counted for your daily totals.
For more information about how to do so, see How do I add, edit, or delete Fitbit data and activities?
@se_0102 Anytime!
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
