10-07-2024
13:57
04:48
10-07-2024
13:57
04:48
Do alarms on clock app on iPhone automatically pull through to fit bit smartwatch?
10-07-2024 15:09
10-08-2024 13:09
10-08-2024 13:09
Many thanks. This is helpful.
If your Fitbit is out of battery, will the alarms in the Fitbit app on a versa 3 ring on your phone instead?
Best Answer10-09-2024 04:54
10-09-2024 04:54
Hi there, @dlstan. Welcome to the Fitbit Community Forums. Thanks for bringing this to question, we're here to answer your inquiry.
As @Odyssey13 has shared with you, only the alarms you set directly on your Inspire 3 will go off. Regarding the battery question, no, the alarms won't ring on your phone. Your Inspire 3 won't pick the alarms you have set on your phone neither your phone or Fitbit app will ring to notify you about the alarms you've set on your Inspire 3 if it runs out of battery. For more information, see How do I manage alarms on my Fitbit device?
