Welcome to the Fitbit Community, @Rick1368. Thank you for sharing your temperature units query.
As @Guy_ has suggested, please make sure you've changed the weather units as follows:
If the above doesn't do the trick, I'd recommend to try switching to a clock face that actually shows both units of measurements, Celsius and Fahrenheit, as not all clock faces will show the temperature in Celsius or Fahrenheit even when you've set it to be that way, probably that would explain why none of the clock face
