Versa 2 -Cycle tracking
How do I add ‘bike’ to the list when tracking on Versa 2?  It used to show up but since recent updates it doesn’t show
Moderator edit:  updated subject for clarity
10 REPLIES 10
@Izzylynn , A warm welcome to the Community! Thank you for your message.
The activity bike should appear listed with all the activities supported by the Versa 2 on the exercise app.
When you open the exercise app, you should see the icon for the 3 most used activities. If you scroll down, you should see a button with the text "show all" or "more".
After pressing the button you should see the list of all activities that can be tracked with the Versa 2.
if you don see it, please attache a picture of your watch with the exercise app open, so that we can see what you are looking at.
@Izzylynn Hi. Are you referring to exercise shortcuts, or auto recognised exercises? No recent updates have changed mine.
When I touch the + sign to start tracking, “bike” isn’t listed and I can’t find a way to have it added
@Izzylynn Plus sign? If I click exercise on the Versa 2, it brings up my shortcuts. I don't have a plus sign.
Try this. On the app, click the top left battery percentage icon. Then your Versa 2. Scroll down to exercise shortcuts. You can swipe to remove something, or click the + to add bike if it's missing. Is this where yours is off?
Bike is listed in shortcuts where you say.  It’s when I start tracking, I only get walk, run, hike options.  I can’t see a way to add bike
@Izzylynn It sounds like you are trying to start from the phone with mobile track? There is not an option for bike on mobile track. Start your ride from the watch?
Didn’t think I had GPS on the watch. Previously I always had to track using the app.  But will check this out.
@Izzylynn The Versa 2 has connected GPS. Uses your phones GPS.
Thanks for your help Mark.  I didn’t know that
@Izzylynn You're welcome. Hope it works out for you.
