07-10-2018 18:03
07-10-2018 18:03
I'm confused how the 7-day total is calculated. Hopefully someone can explain for me.
My current 7 day total is: 63,992
My last 8 days, starting with the oldest, are:
The last 7 days add up to 75,151. Or, if you ignore today's steps and just use the last 7 full days, the total is 64,572.
What am I missing?
Best Answer07-10-2018 23:08
07-10-2018 23:08
Hi @Piscean
The Fitbit week gives you seven days of your steps. Each day will be different because you lose a day. Your seven days go back from today (Tuesday) to last Monday. Tomorrow last Monday's steps will be gone from your seven days total.
You should be fine, as this is how the Fitbit adds up your steps. You can see your individual days, an entire week or more, if you wish. You can go to the calendar and select any time period to view your steps.
Also, some people begin their week on Monday and some on Sunday.
Let us know if you need further assistance.
Best Answer07-11-2018 01:10
07-11-2018 01:10
I can't say for sure how it is calculated because I've not had the Versa for 7 days yet. However, the "weekly total" on my dashboard is the sum of all days including today up to now, so it looks as if it is adding up the past six days plus whatever is accrued for today.
On the other hand, the "7-day average" looks to be calculated on seven days to midnight last night. So it's worked out on a different basis to the "weekly total" and doesn't include steps taken today.
Is it possible you copied any of the daily totals wrongly? (That's what usually happens to me
By the way, when I add up your numbers from 1 (oldest?) to 7 (yesterday?) I get 78010.
Best Answer07-11-2018 01:23 - edited 07-11-2018 01:25
Just to add, on my dashboard, the "7 day total" shows the same number as the "weekly total". (Sorry if the terminology I used was confusing.)
(I just realised I could have edited my previous post. I'm new here :))
Best Answer07-11-2018 01:40
07-11-2018 01:40
Another possible factor here is that the 7 day total on the friends list only includes those steps that were directly tracked by the fitbit. Any steps from manually logged activities or from syncing to other apps will show on the dashboard but will not be included in the friends list total (or in challenges)
Best Answer07-11-2018 07:59
07-11-2018 07:59
You're right about the last 7 days adding up to 78,010. Oops.
I'm guessing you are also correct that the 7-day total is the past 6 days, plus some partial count of today's steps. But if that's what is happening, it seems odd to display 11,191 for my current step count for the day, but then use some number less than that in the 7-day calculation.
Best Answer07-13-2018 05:44
07-13-2018 05:44
Would you know why daily steps are showing but not being added to the weekly steps where it shows your list of friends and weekly steps?
Best Answer07-13-2018 05:46
07-13-2018 05:46
This is probably caused by a bug with the 7 days steps that fitbit is investigating. Keep an eye on the following thread which has their latest updates on the problem:
Best Answer07-13-2018 05:47
07-13-2018 05:47
Thank you for the reply and link.
