12-22-2019
19:36
03:54
JuanJoFitbit
12-22-2019
19:36
03:54
JuanJoFitbit
I just received my new versa 2 and I have it in the charger but I’m uncertain if it is charging as there is no indicator or percent. How long should it charge for the first time? Others have reported they had some battery life when they received theirs but mine appears to be completely drained of battery.
12-23-2019 03:53
12-23-2019 03:53
@Skhaz, welcome to our Fitbit Community! Regarding your inquiry about the time needed in order to have your Versa 2 fully charged is 2-3 hours.
I would like to know if your watch vibrates or turns on when putting it on the charger.
Looking forward to your response.
Best Answer12-23-2019 07:48
12-23-2019 07:48
@Skhaz the only sign of correctly charging will be the vibration when connecting up to charger.. You can remove and reconnect, the charge level should be displayed. Or swipe up on the screen to see the level.
05-20-2020 03:47
05-20-2020 03:47
Just purchased the fitbit versa 2 and it doesn't appear to be vibrating when placed on the charger. Is this normal for the first charge
Best Answer06-03-2020 04:38
06-03-2020 04:38
Hi all, I have a versa 2 and it has taken 12 hours to charge fully. Why is this so? It has never charged 2-3 hours?
Best Answer07-08-2020 02:27
07-08-2020 02:27
Mine has also been charging for over 4 hours and still not done, I was also wondering if that was normal
Best Answer10-14-2020 17:20
10-14-2020 17:20
Hello I just purchased my new fitbit versa 2 and put to charger but doesn't make sound and is already 2 hours charging but it is not charge and is switch off so pls help me😉
Best Answer10-15-2020 00:35
10-15-2020 00:35
Depending on the type of wall wort will depend on how long it will take.
However until the tracker is setup you will not get any notice of the battery state or if it is charging.
Of course you can set the tracker up a little after plugging it into the charger.
Best Answer10-15-2020 02:37
10-15-2020 02:37
I was trying to set up BUT connection was lost so now i am trying to do again and Bluetooth can't find my watch....
Best Answer10-30-2020 12:52
10-30-2020 12:52
Have you been able to set it up? Your Bluetooth is not suppose to find the tracker.
Best Answer06-19-2023 07:18
06-19-2023 07:18
I have a Fitbit Versa 2. 4 mths ago I decided to try a new watch, and put my Fitbit in a drawer. Now, I trying to revive it. I tried turning it on and nothing. I tried multiple attempts to hold the button for 10 sec, and still nothing. Ok, it was dead. I found the charger (original), and put it on it for 2 hours with a high quality USB charger.( have dozens to choose from). After the 2 hrs, still nothing. I mean the watch on the charger doesn't even get warm. Nada. I'm going to leave it on the charger for a longer period, but I'm too encouraged that it will come to life. If not, what are the next steps I could try? I scoured the web for every possible solution, but so far it seems to be out of commission - for good!
Best Answer06-19-2023 07:21
06-19-2023 07:21
BTW, I carefully looked at the seating of the watch in the charger, and can confirm it's making contact with all 4 pins. And, yes, I even cleaned both set of contacts.
Best Answer06-20-2023 02:11 - edited 06-20-2023 06:35
Once you let a lithium battery go dead, it starts to, internally breakdown. The longer the battery is left dead, it is very possible, because of lack of use and uncharged, the battery is dead.
I've seen where it has taken 6+ hours before I could say the battery was charging, but because of not properly maintaining the battery, the charge didn't last long
Best Answer06-20-2023 07:19
06-20-2023 07:19
Hi @redjr - there is one other possibility if you owned a Versa previously - it has an identical charger but it won't charge a Versa 2.
With the correct charger on a PC port insist with the charging, disconnecting and connecting multiple times over a period.
You can always use a USB charge monitor to see if it is drawing any current, which might be small until the battery wakes.
