06-17-2018 16:45 - last edited on 11-16-2020 19:20 by LiliyaFitbit
screen on my very new Versa seems to be getting dimmer. is there a brightness adjustment?
06-17-2018 18:44
06-17-2018 18:44
Yes. Go into Settings on the device and you will see Brightness. It scrolls to normal, dim, auto, and max (or bright).
06-17-2018 18:44
06-17-2018 18:44
06-18-2018 04:21
06-18-2018 04:21
thank you, very easy once i knew where to look
Best Answer11-03-2018 08:10
11-03-2018 08:10
I can't find "BRIGHTNESS" under settings. Am I not looking in the right place?
01-07-2020 12:22
01-07-2020 12:22
There is no brightness in my settings!! What do I do?
Best Answer01-07-2020 12:33
01-07-2020 12:33
On your watch swipe across to the settings and the brightness setting it is there its the first one top of the page all u do is u click it the brightness how bright you wanted to be
01-29-2020 13:27
01-29-2020 13:27
Tried to follow directions. No luck.Could not get the screen brighter.Then my band broke!!! So putting the new one on,I must have pushed the right combination of buttons to show me the sun and moon symbols!It worked!!!😀
Best Answer01-29-2020 13:30 - last edited on 01-29-2020 17:35 by LiliyaFitbit
Better lucky than good!
I have had no problem with brightness. Swipe to settings and brightness pops up.
Best Answer08-10-2020 14:13
08-10-2020 14:13
I can’t get the Brightness out of Dim. I touch on Brightness ( which is not in bold) and it won’t change to BRIGhT
08-10-2020 14:15
08-10-2020 14:15
It will not move. Stays on Dim
08-11-2020 11:20
08-11-2020 11:20
I have the same thing. Several settings are no longer selectable including brightness, screen wake, DDD. So now my watch won't turn on with the wrist and it's super dark, going to need a hotfix for this last patch is seems because this is really bad.
10-30-2020 19:19
10-30-2020 19:19
My brightness will no allow change either. It is set on dim. Also the Screen Wake mode is set at manual, and not in bold. I can't change this either. First I noted this problem was after I changed the clock face to the new blood oxygenation face. Not sure if that changed it.
Best Answer11-25-2020 10:14
11-25-2020 10:14
I see the word Brightness but the word is faded out . Nothing happens when I click on it. Anything else I can do?
Best Answer04-11-2023 15:04
04-11-2023 15:04
I tried it on my Versa also. Brightness is dimmed out and it can not be changed. Looks like I need something that really works as advertised.
