11-27-2021 22:29 - last edited on 12-18-2022 20:40 by MatthewFitbit
If you set the temperature in the Fitbit App [profile photo => App settings => Units => temperature] and you are still not getting the degrees in Fahrenheit or Centigrade as you have defined it, it is because the Weather app has its own settings.
To fix the temperature degrees for Weather:
In the Fitbit App click
Then sync the watch.
For weather showing directly on the clock face there may or may not be a clock face setting to change.
If it is still a problem,
for more information see How do I set up and troubleshoot apps on my Fitbit device?
01-20-2022 08:25
01-20-2022 08:25
Had the same problem. Thanks to Fitbit chat, this solved it.
01-29-2022 07:35
01-29-2022 07:35
Thank you thank you thank you!
02-12-2022 10:04
02-12-2022 10:04
After an extensive chat event, got it resolved. Thanks.
03-29-2022 09:54
03-29-2022 09:54
Oh my gosh thank you so much this has been driving me bonkers.
04-28-2022 17:30
04-28-2022 17:30
Thanks you now I have one less issue i my life
05-08-2022 16:19
05-08-2022 16:19
Thank you for your instructions. When I follow the app trail, in the app list, weather does not appear.
I'm not sure I understand your other set of instructions. Where do I remove cities? In the weather app on my phone? That app was already set for current location.
Note: Just received a replacement Versa 3. Maybe the process of adding a new device messed it up. Is that possible?
05-08-2022 18:02
05-08-2022 18:02
Hello @dbtrueheart
I will try to help you better understand. Open your Fitbit App, then tap your profile picture in the upper right corner, now scroll down and tap the name of your Fitbit (example: Versa, Inspire, Charge) Now tap Gallery…Next scroll all the way down the page and tap weather. Next tap settings….now tap unit, place a check mark on the choice you prefer either Fahrenheit or Centigrade. Finally tap done. Tap the word “Today” to return to the main page. Sync your Fitbit device to accept the new change you made.
if you prefer to watch a quick YouTube Video with visual step-by-step visual instructions look here: https://m.youtube.com/watch?v=VNltgLkqf7c
😃 I hope this helps
06-11-2022 09:25
08-08-2022 07:34
08-08-2022 07:34
Finally changed!! Thank you so much for this info!
08-09-2022 08:29
08-09-2022 08:29
Your solution worked great Thank you Blue Shirt Guy
08-12-2022 14:27
09-17-2022 03:05
09-17-2022 03:05
Thank you It fixed the problem!!!!
09-18-2022 21:50
09-18-2022 21:50
Thank you so much!! I followed your instructions. And they work perfectly! Thank you again.
Now... can you direct me to a miracle fix for my sleep tracking? I've tried all the tips and tricks and none of them work.
10-19-2022 21:48
10-19-2022 21:48
Still doesn’t change
03-02-2023 10:24
03-02-2023 10:24
It’s not the temp on F or C. It’s time on 12 vs 24 hr mode. I prefer the 12 hr vs military time. No problems with ° form
04-14-2023 07:57
04-14-2023 07:57
I have the same issue with the 12 vs. 24 hr time format on the weather app. I just got the Versa 4 yesterday and am surprised at some of the issues. I had Versa 2 and never a problem. Frustrating. After scrolling thru the responses, I assume it's not fixable ??
