11-12-2018
11:38
07:32
JuanJoFitbit
11-12-2018
11:38
07:32
JuanJoFitbit
How do you change setting from Celsius to Fahrenheit.. I've gone to advanced settings and there's no option for setting.. This is a Versa.. All other settings are in US measurements ...
Best Answer11-13-2018 07:45
11-13-2018 07:45
11-12-2018 20:30
11-13-2018 07:31
11-13-2018 07:31
@SunsetRunner It's great to see you in our Fitbit Community! I would like to follow up and would like to know if you were able to change the temperature settings after following the tips that my friend @Marrrmaduke suggested.
Looking forward to your response! ![]()
11-13-2018 07:45
11-13-2018 20:23
11-13-2018 20:23
@SunsetRunner Have you read the post I linked? There's no single option yet, but you can do it by switching Units in your account (km to miles etc.).
@JuanJoFitbit Thanks!
11-13-2018 20:34
11-13-2018 20:34
Best Answer11-13-2018 20:35
11-13-2018 21:00
11-13-2018 21:00
Best Answer11-14-2018 12:11
11-14-2018 12:11
@SunsetRunner I must admit I am a bit surprised as it seems to work on my end. Which version of Android you're running, also which Fitbit firmware version and Fitbit mobile app version? This might have to be addressed with the next update. You might have to contact customer support to open the ticket.
11-14-2018 18:42
11-14-2018 18:42
Best Answer11-14-2018 21:00
11-14-2018 21:00
@SunsetRunner I do not have 2.2 (.19) firmware yet, so I cannot really compare and say why the settings do not work. At this point, the weather app needs to be updated. The only thing that comes to my mind is to try iPhone if you have an access to one. Some users reported that they have a settings icon within weather app itself. Though, they were using 2.1 firmware.
11-18-2018 16:12
11-18-2018 16:12
Option doesn't exist...
Best Answer11-18-2018 18:14
11-18-2018 18:14
@SunsetRunner I think at this point, we need to wait for the weather app update. In the meantime, perhaps you could install a clockface that displays temperature as well? I know it's not the same. Sorry I couldn't be of more help.
11-19-2018 09:23
11-19-2018 09:23
Best Answer12-06-2018 06:06
12-06-2018 06:06
I have a Versa and I have an IPhone and I can’t figure out how to change the temp to Fahrenheit either. All my units are in “American” except temp
Best Answer12-06-2018 12:08
12-06-2018 12:08
@AliciaZim Several iphone users have reported that there's a setting icon within Weather app itself. Open your Fitbit mobile app, tap on Versa icon, go to Apps, Tap on Weather and Open Settings. There should be another gear cog icon for Temperature. I do not have it within my Weather app as I am on Android.
Best Answer12-07-2018 14:17
12-07-2018 14:17
12-08-2018 08:18
12-08-2018 08:18
@AliciaZim I'm so glad to hear that the workaround that shared @Marrrmaduke helped you to get this issue resolved. Thank you for posting the update here.
I'd like to invite you to visit our Discussions board, where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often! ![]()
12-15-2018 17:43
12-15-2018 17:43
My temp setting is in Celsius as well. I have an Android Galaxy Note 8 .......
Best Answer12-15-2018 18:34
12-15-2018 18:34
@Tkayser Android users need to wait for an update to the app as far as I know. Hopefully soon.
