11-17-2018
09:31
10:15
HeydyF
11-17-2018
09:31
10:15
HeydyF
On the weather app, my fitbit Versa is displaying the temperature in Celsius format. How do I change it to display in Fahrenheit? Thanks!
11-17-2018 13:16 - edited 11-17-2018 13:17
In the app on your phone, go to the Versa.
Then click on Apps.
Click the weather app.
Click on settings.
Select Fahrenheit under Temperature unit.
Should change to Fahrenheit on your watch with the next sync.
Then click on Apps.
Click on settings.
11-17-2018 16:44
11-17-2018 16:44
12-21-2018 15:16
12-21-2018 15:16
I followed the directions to change from celcius to farinhit. On my clock it is correct on my weather app it still shows celcius.
12-23-2018 06:41
12-23-2018 06:41
I am having the same problem. The setting is correct in the Fitbit app “settings” for the weather app, but even after syncing it shows C vs F.
12-25-2018 19:08
12-25-2018 19:08
Once in the weather app, i don’t have a settings option
12-25-2018 19:17
12-25-2018 19:17
Where is the weather app?
12-25-2018 19:52
12-25-2018 19:52
Found it. Had to find on phone
12-27-2018 09:50
12-27-2018 09:50
The settings option (gear) is not available on the PC version (Windows 10) of the Fitbit app. I was able to see the gear on my phone (android/Samsung).
01-20-2019 09:37
01-20-2019 09:37
when I try to change weather app unit of measure, after selecting the option, my versa doesn't find my WIFI although it is connected, just continues to search and then message comes up with option to "try again", Any suggestions?
01-24-2019 16:54
01-24-2019 16:54
Thanks worked, so much easier than trying to convert myself.
02-17-2019 10:28
02-17-2019 10:28
There are no app settings in my weather app to change from Celsius to Fahrenheit.
03-06-2019 04:13
03-06-2019 04:13
Didn't work for me.
03-27-2019 04:50
03-27-2019 04:50
Mine either. I was farenheit then this morning woke up to Celsius.
03-28-2019 16:38
03-28-2019 16:38
Thanks. It was easy if you know how.
03-30-2019 09:34
03-30-2019 09:34
After changing to Fahrenheit on the Fitbit app on my iPhone(following the steps provided) and syncing when I open the weather app on my Versa still shows Celsius
03-30-2019 09:36
03-30-2019 09:36
Did you find a way to fix this? I am having the same problem
03-30-2019 09:57
03-30-2019 09:57
03-30-2019 12:33
03-30-2019 12:33
03-30-2019 12:55
03-30-2019 12:55
I not really sure how to help you I just followed the steps listed and it worked, but I have an a Galaxy S9.
