Hello,
I haven't found the setting to deactivate Bluetooth on my Fitbit Versa. On other smartwatches, this is a standard feature (simple, right?). Where can I find the setting? I only want to activate Bluetooth for synchronizing the watch but want to turn it off otherwise.
Thanks!
If I understand correctly, the Versa 2 allows users to connect to Bluetooth, but does not have a disconnect option. For this reason, disconnecting must be initiated with the phone. On an iPhone, enter Settings, then enter Bluetooth, and tap the encircled letter I for a “forget this device” option. This will disconnect Bluetooth. You will have to reconnect Bluetooth to sync, but this can be accomplished pretty quickly.
I hope this helps!
Best AnswerI need to disable Bluetooth on the Versa itself, not my phone. Does anyone know if this feature will come? I don't really want to ditch my Versa (thought about upgrading soon to Versa 3) but being able to deactivate Bluetooth and Wifi (airplane mode) on the product itself is a vital feature for me.
Hi,
i am new here and I would like to know if any Fitbit fitnesstracker allows to deaktivate Bluetooth.
