When setting up my Versa for the first time I accidentally started a Run activity. Now whenever I swipe up on my VersaI I have this Run Activity show up. How can I delete this from my Versa so it doesn't appear anymore when I swipe up?
Welcome to the forums!
I do not see a way to do it on the device itself. But if you go to the computer under activity, look for a trash can and use that to do it.
Can be done form the App as well. Tap on activity tile. locate the one you want to delete. Tap it and you will see a trash can
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
@WendyB is correct @Ajm_Versa while the event can be removed from the account, it can not be removed from the watch.
As your u add more events this run will eventually get pushed off.
