09-18-2018 13:18
09-18-2018 13:18
I had an older fitbit when it up on my laptop. Now i have a versa and I have it all set up on my phone but i want to see my stats on my laptop. I can't find a way to change from my old fitbit to my new versa and sync it in. Everytime i log in to fitbit on my laptop it shows me my old fitbit and old stats. I am not really techno so need someone to dumb it down so I understand. Thanks Kim
Best Answer09-18-2018 14:46
09-18-2018 14:46
In your browser go to fitbit.com and login with the account email and fitbit password you use on your mobile. New stats will be there and are added to your history from your old fitbit moving forward.
If you wanted a fresh start without historic data, you would have to set up a new fitbit account using a different email address and attach either, or both, trackers to it 😉
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
09-18-2018 15:06
09-18-2018 15:06
Actually, it sounds like when you set up the Fitbit on your phone you chose to establish a new account instead of logging in to your existing account. The easy way to check is this:
Are the addresses from #1 and #2 the same? If not, then do the following:
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
Best Answer09-20-2018 12:25
09-20-2018 12:25
