04-16-2018
13:16
10:07
RobertoME
04-16-2018
13:16
10:07
RobertoME
Is it possibile to disable all haptic feedback, leaving the vibration for notification and alarms?
Thanks
Moderator Edit: Updated Subject For Clarity.
04-17-2018 10:06 - edited 04-18-2018 04:06
Hello @elbax69, nice to see you have joined the Fitbit Community! I was reading you are looking for an option to turn Off the haptic feedback of the Fitbit Versa. So far there is not an option to disable this feature, you can only control the intensity from Normal to Strong.
If this is something in which you're interested, I would like to invite you to visit our feature suggestion board, feel free to contribute with your vote and comments, it would be nice to have your feedback here.
See you later and keep participating.
Best Answer04-17-2018 10:06 - edited 04-18-2018 04:06
Best Answer06-17-2023 23:51
06-17-2023 23:51
It's incredibly annoying. Sometimes I put my arm under my pillow to sleep and the constant haptic feedback wakes me up. It's on sleep mode. I am not happy with my versa at all. Versa 2 was better.
