06-16-2023
19:55
08:14
06-16-2023
19:55
08:14
I set the vibration to max strong. But running at the every 10 min rule, the vibration can't alert me to take a break. The vibration is not strong enough.
Hi @VictorW - unfortunately the Versa 3 has a weak vibration which gets weaker as the battery level falls and has no ability to make a sound at the same time.
If you are interested in testing vibrations have a look at the SimpleVibrate app which allows you to test the 8 types of vibrations.
If you find the persistant Alert vibration strong enough you could try using presetup alarms which you may eventually detect.
Best AnswerIt is not the alarm. It is the running notice. When I set the run exercise, will alert me every 10 min to take a rest. But the vibration is so weak and I can't feel it. And I check the battery was 80% full. What do you mean the battery level falls.......
@VictorW - in principle the timer is a system function so can work at the same time as a run exercise, but there is no automatic repeat function (manual, if you don't leave it) and there is no memory function either.
If you want a more sophisticated timer with this options and more use Simple4Timer but it is not allowed to work as a system function so it can be either timer or exercise but not both.
That is why preset Alarms (also a system function) is possibly better.
You will need to manage the auto pause option by scrolling up the run exercise before you start.
Also consider using the lap timer in the run exercise options. It may give you what you want.
