12-29-2018 16:15
12-29-2018 16:15
I have a Samsung Galaxy 5 and cannot get quick reply
Best Answer12-29-2018 16:23
12-29-2018 16:23
You should be able to with that phone. Do you mean you dont have quick reply listed on the phone? Or there is no quick reply offered on the Versa?
Helen | Western Australia
Best Answer12-29-2018 16:30
12-29-2018 16:30
Best Answer12-29-2018 16:38
12-29-2018 16:38
I cannot get a quick reply on my versa. All I can get is open and close.
Best Answer12-29-2018 16:55
12-29-2018 16:55
That is weird! Try restarting your Versa several times, then make sure notifications is step up correctly in the app and try again. Let us know what happens.
Best Answer12-29-2018 17:30
12-29-2018 17:30
@Nicolel123 Do you have a Samsung Galaxy S5 or a Galaxy Note 5? What is the Android OS you are running? Quick Replies require Android 7.0 or above.
Best Answer12-29-2018 19:01
12-29-2018 19:01
Best Answer12-29-2018 19:52
12-29-2018 19:52
Ahh - that phone is NOT on the Supported Devices List. Which means it may work or it may not. In this case I think it is your phone thatbis the problem and you may not be able to get it to work any better than it is. Sorry.
Best Answer12-30-2018 06:42
12-30-2018 06:42
