Hello,
I put my devices through a lot of wear with work and outdoor activities. I have recently made the upgrade from a fitbit flex (I know old school) and an Alta Hr to a Versa Lite. I want to protect the Versa Lite from scratches and debris and was looking at screen cases/bumpers. However with the Lite being new, all I can find on places such as Amazon is cases/bumpers for the Versa.
Does anyone know if the Versa cases would work on the Lite, I realize the buttons are different but would it fit?. Or if anyone has some suggestions on how they protect their Versa or Versa lite on activities such as mountain biking and rock climbing, I would appreciate it.
-Jeuls
03-19-2019
05:51
04:20
03-19-2019
05:51
04:20
Hi @Jeuls.Bit.
As the Versa Lite and standard Versa are the same dimensions, the Versa bumpers will work on the Lite version. Obviously there will be recesses in the bumper for the buttons on the right hand side, but it shouldn't effect much apart from aesthetics. Should be a good option and offer you protection whilst you're waiting for a Versa Lite one to be released.
Edit -
There are actually some already available for the Versa Lite on Amazon
Hi @Jeuls.Bit, I would give it some time for the bumpers to be released. The Versa Lite is really tough...I put mine through the ringer too and I don't have a scratch on mine or any Fitbit products and have never had an issue.
one cruise ship at a time!
Best AnswerThank you for the reply.. I knew that its only a matter of time before the accessories are released, I just wanted to protect it in the mean time. Its good to know that you dont have scratches etc makes me less concerned knowing that its durable.
05:51
04:20
03-19-2019
05:51
04:20
Hi @Jeuls.Bit.
Edit -
