How to put a 4 digit code on versa
Does anyone know how to set up a four digit code on your versa? Does the code only affect the Fitbit pay?
1 REPLY 1
It has to be used if you are using fitbit pay, but it can be used on its own if you don't use fitbit pay.
There's a good guide from fitbit on setting up and using a PIN for your tracker at https://help.fitbit.com/articles/en_US/Help_article/2250/
