03-17-2020 15:42 - last edited on 03-17-2020 17:08 by LiliyaFitbit
Setting up weather. How ?
Best Answer03-17-2020 17:01
03-17-2020 17:01
Hi @SunsetRunner , type of mobile device? Android or iPhone? Erik
Best Answer03-18-2020 00:03
03-18-2020 00:03
Best Answer03-18-2020 08:59
03-18-2020 08:59
Hi @SunsetRunner , I do not know if setting up the weather for an iPhone or Android are the same, but in Android it works lijke this: In the dashboard of your Fitbit app, press the Versa icon in the Today bar on the left side. It brings you to the page with the tiles like Clock Face, Apps, etc. Press App and you will see "My Apps" and "all Apps". By default My Apps are shown and scroll down untill you see "weather". On the right side of it you will dind the settings icon and press that. You see the page with on top Temperature Unit, you can choose between Celsius and Fahrenheit. Underneath that you see "List of cities" and it should read "current location" if you have enabled that on your phone. If you have not enabled that, do so or press "add cities" and enter the exact location where you live. fitbit will start searching for this location. Finally press "done" and sync your iPhone with your Versa and it should work. Erik
Best Answer03-18-2020 09:25
03-18-2020 09:25
Best Answer03-18-2020 10:30
03-18-2020 10:30
Glad to read that, enjoy it Erik
Best Answer06-03-2020 23:36
06-03-2020 23:36
Yes, it works perfect 👍thanks. I had tried everything without results.
