12-29-2019 11:12
12-29-2019 11:12
If you're finished streaming music how do you close the streaming app (Pandora etc) so that it does not continue to stream. All I see is a pause button.
Thanks
12-29-2019 13:30
12-29-2019 13:30
What device is the music app on?
The Fitbit tracker plays music that has been stored on the device.
The download happens during the charging of the tracker.
Music will stop playing when the pause is pressed or when the headphone/speaker is turned off.
Best Answer12-29-2019 04:56
12-29-2019 04:56
I just got the Versa 2 and yesterday started playing around with music. I played several songs on Pandora and Deezer and then stopped. I didn't really see a way to turn off the music stream and this morning the battery was empty. How do you stop streaming music??
Thanks
Best Answer12-29-2019 12:09
12-29-2019 12:09
Are you asking how to stop playing music that has downloaded to your Versa?
Or are you asking on how to stop future songs from being downloaded to your tracker?
Best Answer12-29-2019 12:30
12-29-2019 12:30
I found your second post and merged the two.
Playing music does use more power, listening to a lot of music may require the tracker to be charged.
I'm still not sure what is being asked. Pandora only updates while the tracker is plugged in.
Best Answer12-29-2019 13:25
12-29-2019 13:25
What I'm asking is how to close a music app after streaming so that it does not continue to run in the background.
Best Answer12-29-2019 13:30
12-29-2019 13:30
Best Answer12-29-2019 13:35
12-29-2019 13:35
"Music will stop playing when the pause is pressed or when the headphone/speaker is turned off"
That's what I was looking for but for some reason the pandora app seemingly continued to run and drained the battery. I may not have tapped the pause button.
This is on a Versa 2.
