05-12-2018 10:06 - edited 05-12-2018 10:07
Looking to hear from fellow IPhone users who have updated to the latest firmware. Are you having any problems? Everything is (well, mostly) working for me. Seeing lots of issues here with new firmware, but most seem to be with android or other phones. Except for some minor issues with sleep logs, I'm in good shape and afraid to update and screw things up.
Best Answer05-12-2018 17:38 - edited 05-12-2018 17:38
I updated. Seems ok. Only thing I noticed is I can’t swipe notifications to delete them anymore.
05-16-2018 05:28 - edited 05-16-2018 05:36
Hi dianewordsmith yes I have problems. The sleep log is not logging correctly. Logs later than I go to sleep and a message on the Fitbit dashboard that says in red ink “connect to the internet to view historical data”. When that message is on then Fitbit app will not sync. I think maybe this is part of the sleep problem if Versa isn’t able to sync. Did not have these problems before update 32.32.10.15? Wish I would not have installed cause no benefit just problems. Fitbit how can I go back to no problems or FIX IT or you at FITBIT NEED TO FIX IT., VERY DISCOURAGING!!! And now to top it off I cannot connect to WiFi in the Fitbit app for Versa and it will not sync. I have tried resetting my Versa.
i have a Versa and an iPhone 7 Plus.
