01-14-2020 15:18
01-14-2020 15:18
What do with your Fitbit if you don’t it to get broken rained on or ruined
Best Answer01-14-2020 15:31 - edited 01-14-2020 15:32
Hi @Snowy_9670 , could you be a bit more specific cause now I do not really understand your problem, regards kuzibri
Best Answer01-14-2020 15:47
01-14-2020 15:47
What do u put in the box :package: because there said leave the box and just ship in a box not the box it came in
01-14-2020 15:53
01-14-2020 15:53
Hi @Snowy_9670 , it's the best to return your Fitbit in the original box with all accesoires that came with it. Regards kuzibri and thanks a lot
Best Answer01-14-2020 16:32
01-14-2020 16:32
by Fitbit they just said to return the Fitbit
Best Answer01-14-2020 16:47
01-14-2020 16:47
Hi @Snowy_9670 , do as you like, but the easiest way is to return it in the original box, so you do not get a complaint afterwards that the return was not complete. Regards kuzibri
01-14-2020 19:29
01-14-2020 19:29
Okay I will do thanks a lot for Your patience and time
