I have upgraded from alta hr to versa. The problem is when I go to check my heart rate readings there are several breaks where it has not detected anything. I never had this with the alta. I have tried to reposition, swap wrists. The only way it stays on is if I wear it on the inside of my wrist. Is thus a normal thing? Thanks
Hello @Amandamummy3
Welcome to the forums and hope you post often.
Have a look here to see if you have it positioned properly.
Also, maybe try a restart on pg.68.
See the link below.
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
