03-13-2020 04:22
03-13-2020 04:22
Incorrect time after charging - how do I fix it to the correct time?
03-13-2020 05:28
03-13-2020 05:28
Have you synced your fitbit since charging? It should reset the time every time it syncs.
Best Answer03-13-2020 06:42
03-13-2020 06:42
Best Answer03-13-2020 06:45
03-13-2020 06:45
Opening the app should trigger a sync and dragging down in the app should also start a sync.
If you select your profile picture in the app it will show when it last synced.
Best Answer03-13-2020 07:09
03-13-2020 07:09
Which watch face do you use? If I use a "non standard" watch face (downloaded) my Versa 2 runs behind a couple of minutes...
Best Answer03-13-2020 08:58
03-13-2020 08:58
Best Answer03-13-2020 09:50
03-13-2020 09:50
I am having the same problem. Currently 4 and a half hours behind . Tried a sync and changing timezones and the clock face. Nothing has worked.
