03-31-2020
06:08
06:26
EstuardoFitbit
03-31-2020
06:08
06:26
EstuardoFitbit
Hoping someone can help! I just received by Versa 2 this morning and can't log my HIIT training. I tried through the watch but I don't think it started and I hadn't realised. Went to dashboard to log exercise and there is no option for interval when I log manually. How do I log my correct exercise?
Thanks 🙂
@taraodonnell I think the easiest way is to actually create a custom activity (so you have it for the future use) on the website. You can go to https://www.fitbit.com/activities and create the activity under Activities in the bottom right corner of the page. Unfortunately, you will be able to add only average stats as shown below:
Of course, this may not be what you really want for HIIT. You can always log a regular workout within the Fitbit app and then rename it to HIIT, but that would give you only basic stats as well.
Best Answer@taraodonnell I think the easiest way is to actually create a custom activity (so you have it for the future use) on the website. You can go to https://www.fitbit.com/activities and create the activity under Activities in the bottom right corner of the page. Unfortunately, you will be able to add only average stats as shown below:
