12-05-2019
06:06
13:08
12-05-2019
06:06
13:08
I've just been given a versa lite for my bday and it says its waterproof but I'm unsure whether to use it when i go swimming.Does it work in water?Any advice please?
Best Answer12-05-2019 09:09
12-05-2019 09:09
Hi @Gedpaddy check under "Specs" in the information on it - click to read it. Happy stepping!
Best Answer12-05-2019 09:19
12-05-2019 09:19
Thank you for your prompt reply! I would like people who have got one and used in the water to give me some feedback if possible.It cost a lot of money so nervous about using it in the water
Best Answer12-05-2019 09:25
12-05-2019 09:25
I'll move this to the Versa area of the forums for more relevant responses. I'm sure someone will let you know!
Best Answer12-05-2019 09:40
12-05-2019 09:40
Thanks again!!
Best Answer12-05-2019 09:45
12-05-2019 09:45
For clarification, no where does the Versa lite, or any watch from any company will claim waterproof. At some point, they all will fail. The correct term is water resistant to X feet or pressure.
For the Versa it is 150 feet, but this is in absolutely calm water and lowering very slowly.
This generally means no diving into water, no deep swimming. No whirlpools. No swimming in water with a strong current.
Doing a search you will find a few posts of people who have had water issues. My understanding is that the screen is glued on.
Then again we have users that often swim in the ocean
12-05-2019 10:03
12-05-2019 10:03
Thank you!
